Vmix
ffmpeg
ffmpeg script or batch file
An example script from Thomasz SPxxx is available for download here: File:sample 333ks 23 s2 440.zip
  • Enter your own station details
  • Line 17 - enter the IP address of your Portsdown / Pluto etc
  • Line 59 - set the video resolution to match the Vmix external output resolution.
Alternatively you can start the file by entering the file name followed by the TS rate required. For example "Tx.bat 440"
Original Portsdown script
Save the file.
Using the system
Now start up vMix and select a video source. Then configure the output, by clicking the cogwheel next to the output label and then clicking Settings.
Note the video resolution should be set to match your ffmpeg script.
More to follow..............
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
