Vmix
ffmpeg
ffmpeg script or batch file
An example script from Thomasz SPxxx is available for download here: File:sample 333ks 23 s2 440.zip
- Enter your own station details
- Line 11 - enter the TS rate required. This is calculated from this page http://www.satbroadcasts.com/DVB-S_Bitrate_and_Bandwidth_Calculator.html based on the parameters you have set for your transmission in Portsdown or Pluto
- Line 17 - enter the IP address of your Portsdown / Pluto etc
- Line 59 - set the video resolution to match the Vmix external output resolution.
Alternatively you can start the file by entering the file name followed by the TS rate required. For example "Tx.bat 440"
Original Portsdown script
Save the file.
- MPEG-2 with added 333kS/S symbol rate: File:VMix2PortsdownExtendedSR.zip
- H.264 encoding: File:VMix2PortsdownH264ExtendedSR.zip
- Adding text overlays (e.g. for callsign, locator): see blog post by Chris MW0LLK for how to add text to the batch file (http://www.tannet.org.uk/using-ffmpeg-to-generate-a-transport-stream-more-details-and-how-to-add-text-overlays/)
To run the file, double click on the file in Windows Explorer, and it should ask for the Video bitrate and FEC, then ask you to press any key.
When you press a key, the window should change to one giving information about the stream being sent towards the Portsdown TX. The stream is simply squirted at the IP address that you entered earlier - it can be left running and the TX does not need to be on.
Using the system
Now start up vMix and select a video source. Then configure the output, by clicking the cogwheel next to the output label and then clicking Settings.
Note the video resolution should be set to match your ffmpeg script.
Next, start the batch file that you edited earlier.
More to follow..............
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
