The method outlined here will also work with other DATV tranmit systems such as the F5OEO custom firmware for the Adalm Pluto. VMix Block.jpg
Vmix
ffmpeg
ffmpeg script or batch file
An example script based on one supplied by from Thomasz SPxxx is available for download here: File:sample 333ks 23 s2 440.zip
  • Enter your own station details
  • Line 17 - enter the IP address of your Portsdown / Pluto etc
  • Line 59 - set the video resolution to match the Vmix external output resolution.
Alternatively you can start the file by entering the file name followed by the TS rate required. For example "Tx.bat 440"
Unless you have set up system paths, these batch files must be saved in the ffmpeg /bin directory
Original Portsdown script
Save the file.
To run the file, double click on the file in Windows Explorer, and it should ask for the Video bitrate and FEC, then ask you to press any key.
When you press a key, the window should change to one giving information about the stream being sent towards the Portsdown TX. The stream is simply squirted at the IP address that you entered earlier - it can be left running and the TX does not need to be on.
Using the system
Now start up vMix and select a video source. Then configure the output, by clicking the cogwheel next to the output label and then clicking Settings.
Note the video resolution should be set to match your ffmpeg script.
Next, start the batch file that you created earlier.
If using the F5OEO Pluto firmware, start transmit.
More to follow..............
The video bit rates in the Portsdown batch file are hard-coded based on what was found to work - a trial and error process to minimise both under-runs and over-runs of the transport stream in the Portsdown software. Both cause picture disturbances. If you want to see the effect of different settings, you can monitor the under-run or over-run by watching the text output from rpidatv. To do this, open 3 Linux terminal sessions; the first one should have the Portsdown Console Menu. Use the console for selecting the desired SR and FEC, but not selecting transmit. Go to the Linux command prompt on the second console to select transmit and watch the buffer messages. Do this by typing:
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
