Revision as of 19:37, 8 January 2020 by G8GTZ (talk | contribs) (→Vmix)
Vmix
Make sure that your PC with vMix and your Portsdown transmitter are on the same wired network.  Wireless networks might work but have not been tested.
Now start up vMix and select a video source. Then configure the output, by clicking the cogwheel next to the output label and then clicking Settings.
Note the video resolution should be set to match your ffmpeg script.
ffmpeg
The next step is to install ffmpeg on your PC. Download the latest build from here: https://ffmpeg.zeranoe.com/builds/
ffmpeg script or batch file
An example script based on one supplied by from Thomasz SPxxx is available for download here: File:sample 333ks 23 s2 440.zip - you can rename it when saving but the name indicates it is set for 333ks 2/3 FEC DVB-S2 and the TS bit rate is 440 kbit/s.
Unless you have set up system paths, this batch file must be saved in the ffmpeg /bin directory
  • Line 2+ Enter your own station details
  • Line 17 - enter the IP address and UDP in port of your Portsdown or Pluto etc
  • Line 59 - set the video resolution to match the Vmix external output resolution.
Alternatively you can remove the rem at the beginning of line 9 and rem out line11 - then start the file by entering the file name followed by the TS rate required. For example "Tx.bat 440"
Original Portsdown script
Save the file.
To run the file, double click on the file in Windows Explorer, and it should ask for the Video bitrate and FEC, then ask you to press any key.
When you press a key, the window should change to one giving information about the stream being sent towards the Portsdown TX. The stream is simply squirted at the IP address that you entered earlier - it can be left running and the TX does not need to be on.
Using the system
  • Click OK on the Vmix external Output button. It should turn red.
  • Next, start the batch file that you created earlier - this must be running before you go in to transmit on the Portsdown.
  • Lastly, set up your Portsdown TX with IPTSIN as the input and identical SR and FEC to that set up in the batch file.
  • Select transmit and it should work. (You can select transmit and standby on the Portsdown console (or touchscreen) without having to sop or start the batch file.)
If using the F5OEO Pluto firmware, start transmit....
More to follow..............
The video bit rates in the Portsdown batch file are hard-coded based on what was found to work - a trial and error process to minimise both under-runs and over-runs of the transport stream in the Portsdown software. Both cause picture disturbances. If you want to see the effect of different settings, you can monitor the under-run or over-run by watching the text output from rpidatv. To do this, open 3 Linux terminal sessions; the first one should have the Portsdown Console Menu. Use the console for selecting the desired SR and FEC, but not selecting transmit. Go to the Linux command prompt on the second console to select transmit and watch the buffer messages. Do this by typing:
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
