Es'hail-2 Ground Station
Revision as of 13:58, 17 February 2020 by M0DNY (talk | contribs) (→‎Software: Add source links.)
Wideband monitor
To log in, type the following in to the box at the bottom of the chat (replacing "my name" with your real name or callsign) and press return:
/nick my name
For example:
/nick G8ABC_Fred
You will get a confirmation message that your name has changed and the text in the box changes to "Type a message here and press enter" - your name also appears in the list on the right handside of the page.
Narrow band SDR
Details of the installation
The equipment is housed in a room dedicated to amateur radio infrastructure in the workshops building for the now defunct GHY2 90 ft dish antennae, built in 1969.
As well as the Es'hail-2 (now known as Qatar Oscar 100) WebSDR and spectrum monitor, the station houses an AMSAT-UK Funcube ground station and an HF Kiwi WebSDR with GPS TDOA.
RF System
Dish
RF Front End
Receivers
GPS reference
Computer System
  • Intel i7-2600 CPU
  • 16GB DDR3 RAM
  • Intel DQ67SW Motherboard
  • 500GB Samsung 850 EVO SSD
Networking
Goonhilly Earth Station has 2x diverse redundant 10Gb links into JANET PoPs. They have been kind enough to give us a dedicated IP address and access to >300Mb/s of up & down bandwidth for use by the station.
A high-bandwidth Leo Bodnar NTP Server provides NTP service to the station & the worldwide NTP Pool. Stats and graphs of this service can be viewed at https://eshail.batc.org.uk/ntp/
