Es'hail-2 Ground Station
Revision as of 13:59, 17 February 2020 by M0DNY (talk | contribs) (→‎Networking)
Wideband monitor
To log in, type the following in to the box at the bottom of the chat (replacing "my name" with your real name or callsign) and press return:
/nick my name
For example:
/nick G8ABC_Fred
You will get a confirmation message that your name has changed and the text in the box changes to "Type a message here and press enter" - your name also appears in the list on the right handside of the page.
Narrow band SDR
Details of the installation
The equipment is housed in a room dedicated to amateur radio infrastructure in the workshops building for the now defunct GHY2 90 ft dish antennae, built in 1969.
As well as the Es'hail-2 (now known as Qatar Oscar 100) WebSDR and spectrum monitor, the station houses an AMSAT-UK Funcube ground station and an HF Kiwi WebSDR with GPS TDOA.
RF System
Dish
RF Front End
Receivers
GPS reference
Computer System
  • Intel i7-2600 CPU
  • 16GB DDR3 RAM
  • Intel DQ67SW Motherboard
  • 500GB Samsung 850 EVO SSD
Networking
Goonhilly Earth Station has 2x diverse redundant 10Gb links into London Datacenters through Next Connex. They have been kind enough to give us a dedicated IP address and access to >300Mb/s of up & down bandwidth for use by the station.
A high-bandwidth Leo Bodnar NTP Server provides NTP service to the station & the worldwide NTP Pool. Stats and graphs of this service can be viewed at https://eshail.batc.org.uk/ntp/
