Renewing your membership
Revision as of 20:46, 19 April 2020 by ON8YY (talk | contribs) (Created page with "Re: LimeSDR-Mini Problems with DATV-Express Quote Post by G4GUO » Fri Feb 01, 2019 9:41 am The latest version of DATV-Express comes up with an Alert Box telling you if yo...")
Post
The latest version of DATV-Express comes up with an Alert Box telling you if you have incompatible hardware. If you are not seeing that message then the firmware is compatible.
My only suggestion is check the USB cable (if you are using one) and check there is enough power from the PC to the Lime. I have a number of USB3 ports on my P.C and only one of them provides enough power (the one with the charging symbol on it)
- Charles
