The project, which was featured in the June 2017 issue of the RSGB's Radcom magazine, involves some basic construction and is based around a Raspberry Pi with a touchscreen and uses a LimeSDR Mini - before January 2019 the Portsdown used a custom filter modulator card and external local oscillator.
Portsdown Evolution
Portsdown 2018 Classic
The was the original version launched in 2017 - Portsdown 2018. It was based on the Raspbian Jessie operating system running on a Raspberry Pi 3 with a 3.5 inch touchscreen. It used the BATC-supplied Filter-Modulator board and could take video from the Raspberry Pi Camera or the EasyCap. It would transmit DVB-S MPEG-2 with audio, or H264 without audio. This version is no longer supported, although it will continue to work as built.
Portsdown 2019 Stretch
This was the second version, using the Raspbian Stretch Operating System - Portsdown 2019. Support for the 7 inch touchscreen was added and some WebCams could also be used as a video source. Audio capability was added for H264 encoding, and early support was provided for the LimeSDR Mini. Later versions also supported the LongMynd receive software enabling good DATV reception using a MiniTiouner. Again, this version is no longer supported, although it will continue to work as built.
Portsdown 2020 Buster
The current in-use version of the Portsdown is Buster 2020 - Portsdown 2020. This introduces support for the LimeDVB firmware on the LimeSDR Mini and also supports the use of standard firmware on the LimeSDR USB and the LimeNET Micro. The LongMynd receive capability has been improved with the addition of a player that will display some H265 signals. It will also control an external Jetson Nano with an HDMI capture device to allow the transmission of high definition H265 signals. This version will continue to be actively supported while the Buster operating system is current for the Raspberry Pi. No date has yet been set for release of the next operating system version (Bullseye).
Portsdown 4
The next version of the Portsdown will be the Portsdown 4. This will use the Buster operating system on a Raspberry Pi 4 with a 7 inch screen and a LimeSDR. Unlike the previous version changes it will not maintain hardware compatibility with the classic (filter-modulator) Portsdown. You may have seen mention of the Portsdown A27 – this version was the stepping stone from the Portsdown Buster 2020 to the Portsdown 4, and will not be continued with that name. First production release of the Portsdown 4 should be during July or August 2020.
System overview
From January 2019 the custom BATC Filter Modulator board has been replaced by a LimeSDR Mini. This covers a wider frequency range and adds DVB-S2 capability.
Touch screen control
The output from the RPi is connected to a LimeSDR Mini (or the original Filter Modulator board) which modulates the RF carrier and produces the DVB-S or DVB-S2 DATV signal.
Audio and video inputs
The Portsdown transmitter will take audio and video inputs from the RPi camera, an EasyCap USB dongle and a USB sound card / dongle - all these are readily available from ebay and Amazon.
