Ryde GPIO Connections
Revision as of 16:03, 16 July 2020 by G8GKQ (talk | contribs) (→Proposed GPIO Connections for the Ryde Receiver)
RPi 4 GPIO pin out
- Note the Rpi4 (only) can be powered with 5v directly on to GPIO 2 and 4.
Here is the proposed list of GPIO connections:
Pin No | BCM No | Wiring Pi | RPi Pri | RPi Alt0 | Primary Use | Secondary Use | Notes |
1 | - | - | 3.3v | - | - | - | - |
2 | - | - | 5v | - | - | - | - |
3 | 2 | 8 | GPIO 2 | SDA1 | - | - | - |
4 | - | - | 5v | - | - | - | - |
5 | 3 | 9 | GPIO 3 | SCL1 | - | - | - |
6 | - | - | 0v | - | - | - | - |
7 | 4 | 7 | GPIO 4 | GPCLK0 | Valid RX Signal | - | Active High |
8 | 14 | 15 | GPIO 14 | TXD0 | - | - | - |
9 | - | - | 0v | - | - | - | - |
10 | 15 | 16 | GPIO 15 | RXD0 | - | - | - |
11 | 17 | 0 | GPIO 17 | FL1 | IR Sensor Input | Active low | |
12 | 18 | 1 | GPIO 18 | PCM_CLK | Button - Up | - | Active low |
13 | 27 | 2 | GPIO 27 | SD0_DAT3 | Button - Down | - | Active low |
14 | - | - | 0v | - | - | - | - |
15 | 22 | 3 | GPIO 22 | SD0_CLK | Button - Left | - | Active low |
16 | 23 | 4 | GPIO 23 | SD0_CMD | Button - Right | - | Active low |
17 | - | - | 3.3v | - | - | - | - |
18 | 24 | 5 | GPIO 24 | SD0_DAT0 | Button - Select | - | Active low |
19 | 10 | 12 | GPIO 10 | SPI0_MOSI | - | - | - |
20 | - | - | 0v | - | - | - | - |
21 | 9 | 13 | GPIO 9 | SPI0_MISO | - | - | - |
22 | 25 | 6 | GPIO 25 | SD0_DAT1 | Button - Back | - | Active low |
23 | 11 | 14 | GPIO 11 | SPI0_SCLK | - | - | - |
24 | 8 | 10 | GPIO 8 | SPI0_CE0_N | - | - | - |
25 | - | - | 0v | - | - | - | - |
26 | 7 | 11 | GPIO 7 | SPI0_CE1_N | - | - | - |
27 | 0 | 30 | ID_SD | SDA0 | Reserved | - | - |
28 | 1 | 31 | ID_SC | SCL0 | Reserved | - | - |
29 | 5 | 21 | GPIO 5 | GPCLK0 | Button - Menu | - | Active low |
30 | - | - | 0v | - | - | - | - |
31 | 6 | 22 | GPIO 6 | GPCLK2 | Button - Mute | - | Active Low |
32 | 12 | 26 | GPIO 12 | PWM0 | Band LSB | - | - |
33 | 13 | 23 | GPIO 13 | PWM1 | Band NSB | - | - |
34 | - | - | 0v | - | - | - | - |
35 | 19 | 24 | GPIO 19 | PCM_FS | Band MSB | - | - |
36 | 16 | 27 | GPIO 16 | FL0 | Button - Power | - | Active low |
37 | 26 | 25 | GPIO 26 | SD0_DAT2 | Button - OSD Info | - | Active low |
38 | 20 | 28 | GPIO 20 | PCM_DIN - | - | Future Use? | |
39 | - | - | 0v | - | - | - | - |
40 | 21 | 29 | GPIO 21 | PCM_DOUT | - | - | Future Use? |
Note that the GPIO pin names are markedly different from the RPi 3B. Each pin on the RPi4 GPIO can be referred to in 4 ways: its physical pin number, the Broadcom I/O number, the Wiring Pi number or the primary or alternate names. Source for GPIO designations was the Raspberry Pi 4 Model B datasheet.
