SUP2400 mods
In order to receive 437 MHz (70cms) DATV on a standard satellite STB, you need to up convert the signal to L band. Luckily there is a consumer device available in the USA which is used on cable networks to up convert UHF signals to L Band where they are then received on a standard satellite box. The units are made by a company called Zinwell and known as SUP-2400. They are available on ebay but only in the US and so are stocked in the BATC shop.
Before use, they they either require hardware modification, or the use of the Diseqc controller - details available here - to work on DATV.
This document describes the hardware modifications.
