Portsdown 4
No other models of Raspberry Pi or touchscreen are planned to be supported in the near future so please don't ask.
Capabilities
- DVB-S and DVB-S2 (MPEG-2 and H264) transmissions from a LimeSDR Mini connected by USB
- DVB-S and DVB-S2 (H264 only) transmissions from a Pluto SDR connected by USB
- DVB-S (MPEG-2 and H264) transmissions from a DATV Express Board connected by USB
- Supported transmit video sources include the Raspberry Pi Camera, C920 WebCam or a USB-connected EasyCap composite video capture device
- Streaming to the BATC Streamer using the Raspberry Pi Camera or EasyCap composite video capture device
- Reception and display of DVB-S and DVB-S2 (MPEG-2, H264 and H265) signals received by a BATC MiniTiouner Mk 2 connected by USB.
- Display of streams from the BATC Streamer
Currently not everything is working, so have patience.
The software build is also compatible with the Langstone Microwave transceiver software, which can be loaded by from touchscreen selections (menu 2) AFTER the Portsdown software has been installed. To operate, the Langstone software needs a Pluto to be connected by USB, and a compatible USB Audio dongle.
The build is on GitHub at https://github.com/BritishAmateurTelevisionClub/portsdown4
FAQ
- Is it possible to rotate the PiCam image in software as it is on it's side?
- Can I upgrade from Langstone or a previous version incluing Portsdown A27?
More information
For early release information see https://forum.batc.org.uk/viewtopic.php?f=103&t=6804
