Ryde FAQ
Although I have a picture on my HDMI Monitor, I am not getting any sound.
Some HDMI monitors can be detected by the Raspberry Pi as DVI monitors. Add the line "hdmi_drive=2" to /boot/config.txt to force HDMI and reboot.
Everything seems to be working, except I only get "Locked No Video" on the screen, never a picture.
Make sure that you have the HDMI monitor plugged into the primary HDMI socket - that's the one nearest the USB-C power socket.
I need to use a Composite Video input monitor, not an HDMI monitor.
Select the display option that you want in the ssh Console Menu.
When I use a Composite Video Monitor, I lose some of the edges of the display.
Add the line "overscan_scale=1" to /boot/config.txt and reboot.
I can't save changes to /boot/config.txt
The file /boot/config.txt is owned by root, so you will need to use the command "sudo nano /boot/config.txt" to edit it.
I am losing the edge of the screen off my monitor.
Try adding the line overscan_scale=1 to /boot/config.txt. You will need to use the command sudo nano /boot/config.txt to do this.
After my Ryde has been waiting for a signal for a reasonable length of time, the display screen goes blank
Check the time-out (sleep?) settings on your HDMI display. The Ryde continues to output a (Not Locked) image for days on end.
Does the Ryde work with the MiniTiouner Pro V2?
Yes. Use Tuner Input A and the USB Master socket. One user had to comment out lines 114-117 of stvvglna.c and rebuild, but this seems to have been a transient (now cured) fault with his particulare tuner.
