Knucker
Revision as of 09:48, 29 December 2020 by G8GTZ (talk | contribs) (→‎Hardware)
Why Knucker
Why not?
Timescales
December 2020 - Currently the project is at the design phase with a proof of concept receiver working on bread board hardware.
Receiver
Note: the 4762 NIM is capable of DVB-T and DVB-S but the DVB-S is NOT (repeat NOT) supported in any BATC applications.
The PCB design by Mike G0MJW is based on the MiniTiouner Version 2 board - the photo shows the first built and tested prototype .
BOM and schematics are available here: File:Knucker.xlsx
It is intended to develop a core Linux DVB-T receiver application that will be integrated into the LongMynd receiver core.
It is planned that the Portsdown DATV system will be enhanced to include the DVB-T receiver.
It is envisaged that a set-top box version of the code will be developed using the RydePlayer and would be known as the Knucker receiver.
Transmit
DATVexpress
Charles G4GUO is currently developing a variable bandwidth OFDM version of the DATVexpress software. This will work with the DATVExpress card, Pluto and Lime SDR.
Beta testing
We will be looking for technically competent people to help test the system in it's intended applications - low band VHF, HF and mobile.
Send us an email if you are interested in helping.
Applications
DX!!
DVB-T can be used in environments where phase distortion and multi-pathing means DVB-S does not work. Typical applications include mobile video transmissions and bands below 70MHz :-)
