Knucker
Revision as of 21:49, 7 January 2021 by G8GTZ (talk | contribs)
Why DVB-T
DX!!
DVB-T can be used in environments where phase distortion and multi-pathing means DVB-S does not work. Typical applications include mobile video transmissions and bands below 70MHz :-)
Why Knucker
Why not?
Timescales
December 2020 - Currently the project is at the design phase with a proof of concept receiver working on bread board hardware.
Receiver
Version 1
Version 2
This was the first protype build and not on general release - BOM and schematics are available here: File:Knucker.xlsx
Version 3
First general release PCB - if you bought your PCB from the BATC shop, this is the information you need.
Note the use of a 3 pin 1.2v regulator which is different from the 5 pin variable 1.2v regulator on the MiniTuioner V2 PCB
Schematic is here: File:Knucker schematic V3.pdf
BOM is here File:knucker BOM V3.xlsx
USB Module
The USB module will require reprogramming with the xml file in this zip using the FTDI program called FT prog - the standard MiniTiouner USB module from the BATC will not work but can be re-programmed.
File:combituner.zip
Full instructions on how to program the unit are here: http://www.vivadatv.org/viewtopic.php?f=80&t=379
It is intended to develop a core Linux DVB-T receiver application that will be integrated into the LongMynd receiver core.
The first product implementation will be in the Portsdown DATV system which will be enhanced to include a DVB-T receiver.
It is also envisaged that a set-top box version of the code will be developed at some point using the RydePlayer and would be known as the Knucker receiver.
Transmit
DATVexpress
Charles G4GUO is currently developing a variable bandwidth OFDM version of the DATVexpress software.
This will work with the DATVExpress card, Pluto and Lime SDR.
