Knucker
Revision as of 18:01, 13 January 2021 by G8GTZ (talk | contribs) (→‎Version 3)
Why DVB-T
DX!!
DVB-T can be used in environments where phase distortion and multi-pathing means DVB-S does not work. Typical applications include mobile video transmissions and bands below 70MHz :-)
Why Knucker
Why not?
Timescales
December 2020 - Currently the project is at the design phase with a proof of concept receiver working on bread board hardware.
January 2021 - beta testing in progress
Receiver
Version 1
Version 2
This was the first protype build and not on general release - BOM and schematics are available here: File:Knucker.xlsx
Version 3
First general release PCB - limited availability in late January 2021.
PCB Image
USB Module
The USB module will require reprogramming with the xml file in this zip using the FTDI program called FT Prog - the standard MiniTiouner USB module from the BATC will not work but can be re-programmed.
File:combituner.zip
It is intended to develop a core Linux DVB-T receiver application that will be integrated into the LongMynd receiver core.
Portsdown receiver
The first product implementation will be in the Portsdown 4 (only) DATV system which will be enhanced to include a DVB-T receiver.
Dave G8GKQ released the first alpha code for testing in early January 2021.
Other receive developments
It is also envisaged that a set-top box version of the code will be developed at some point using the RydePlayer and would be known as the Knucker receiver.
Transmit
DATV Express
Portsdown system
Due to excellent cooperation between Charles and Dave, it looks like Dave has tested a prototype DVB-T transmitter in Portsdown - watch this space!
https://twitter.com/davegkq/status/1348758581278105602?s=20
