Knucker
Why DVB-T
DX!!
DVB-T can be used in environments where phase distortion and multi-pathing means DVB-S does not work. Typical applications include mobile video transmissions and bands below 70MHz :-)
Why Knucker
Why not?
Timescales
January 2021 - beta testing in progress
The planned project release is currently March 2021 (but subject to change). 400 Serit NIMs on order due early March in plenty of time for the sporadic E season :-)
Receiver
Version 1
Version 2
This was the first prototype build and not on general release - BOM and schematics are available here: File:Knucker.xlsx
Version 3
First general release PCB - limited availability in January 2021. General release March 2021
PCB Image
USB Module
The USB module will require reprogramming with the xml file in this zip using the FTDI program called FT Prog - the standard MiniTiouner USB module from the BATC will not work but can be re-programmed.
File:combituner.zip
Charles G4GUO has developed a core Linux DVB-T receiver application that is being integrated into the LongMynd receiver core.
Portsdown receiver
The first product implementation will be in the Portsdown 4 (only) DATV system which will be enhanced to include a DVB-T receiver.
Dave G8GKQ released the first alpha code for both Portsdown transmit and receive testing in mid January 2021.
Other receive developments
It is also envisaged that a set-top box version of the code will be developed at some point using the RydePlayer and would be known as the Knucker receiver.
Transmit
DATV Express
Portsdown system
Due to excellent cooperation between Charles and Dave, a prototype DVB-T transmitter in Portsdown was released in Mid January.
https://twitter.com/davegkq/status/1348758581278105602?s=20
