Knucker
Why DVB-T
DX!!
Why Knucker
Why not?
Timescales
January 2021 - beta testing in progress
The planned project release is currently March 2021 (but subject to change). 400 Serit NIMs on order due early March in plenty of time for the sporadic E season :-)
Receiver
Note that the DVB-T input to the NIM is the one nearest the PCB. The upper connector is for the DVB-S/S2 section of the NIM which is not used (and will not be, as the performance is not as good as the NIM used on the MiniTiouner).
Version 1
Version 2
This was the first prototype build and not on general release - BOM and schematics are available here: File:Knucker.xlsx
Version 3
First general release PCB - limited availability in January 2021. General release March 2021
USB Module
The USB module will require reprogramming with the xml file in this zip using the FTDI program called FT Prog - the standard MiniTiouner USB module from the BATC will not work but can be re-programmed.
Charles G4GUO has developed a core Linux DVB-T receiver application.
Portsdown
This has been integrated into the Portsdown 4 system. https://forum.batc.org.uk/viewtopic.php?f=103&t=7158
Ryde set top box
An interim SSH Menu-driven version has also been integrated into the Ryde Build. No remote control functions are available in this build, although full integration with Ryde is on the to-do list.
Transmit
Portsdown system
Due to excellent cooperation between Charles and Dave, a Portsdown DVB-T transmitter using the Pluto SDR has been integrated into the Portsdown 4.
The first official release was made on 1st February 2021
https://forum.batc.org.uk/viewtopic.php?t=7158&p=26210#p26210
DATV Express
