Getting Started
Revision as of 21:44, 2 July 2021 by G8XZD (talk | contribs)
One of the aims of the BATC is to help members get on the air and to this end the club has come up with the Portsdown project which is easy enough for most people to successfully build at home.
Hundreds of these have been built by amateurs around the world and part of its success is down to the club prescribing the key components/design (and you sticking to them...) and following simple build instructions.
Yes I know radio amateurs (me included) like to tinker and experiment but at this stage it really helps our volunteers help you. That way, if there are any problems, it's easy to offer support via the BATC forum. And if you still can't get it going bring it along to one of our Portsdown clinics which are held at most rallies the BATC attends.
But if this all sounds overwhelming there's an easy way to "get on the air" using transmitter/receiver modules - if so take a look at this page which shows you how to join in the fun on 5.6GHz for around £20.
=== The best way forward ===
We often get asked how do I start to receive or transmit DATV?
Receiving DATV
Probably the most repeatable way to do this is to build up a Minitiouner board. Developed by Jean-Pierre Courjaud, F6DZP, this can either be used with his excellent free MiniTioune Windows software downloadable here: http://www.vivadatv.org/viewforum.php?f=60
You can buy the PC board and other "hard-to-get" components from the BATC shop https://batc.org.uk/shop/ - the remainder are standard leaded (no surface mount) components, available from all major suppliers. and can easily be put together in an evening.
With this you can receive local DATV activity from 2m to 13cm, including digital TV repeaters, and with a satellite dish and LNB, you can watch the activity on QO-100.
Jean-Pierre's software also comes with a suite of programmes to allow you to test that the board is talking to the software correctly.
You will then need the normal aerials, filters/pre-amps and/or LNB depending on the band you want to receive. Having said that it is sensitive enough on its own to be able to receive nearby activity - and probably your local TV repeater.
To find out more, or ask for help, have a look in the Minitioune section of the BATC forum. https://forum.batc.org.uk/viewforum.php?f=105
DATV transmit
For more details see ttps://wiki.batc.org.uk/The_Portsdown_Transmitter
The Portsdown software includes everything you need - just make sure you have the latest Portsdown build - and plug your tuner card in to the Raspberry Pi USB port. See https://wiki.batc.org.uk/Portsdown_4_Pluto for more details.
