To build the unit you only need to buy the following components from the BATC shop [1].
- The ready programmed USB interface.
- The version 2 main PCB.
- The Serit tuner or NIM covering 143 - 2450 MHz. NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
- The unit uses an adjustable MCP1826 as the 1V regulator, which can be hard to find.
Mike, G0MJW, has written an excellent guide on building and testing the board - download them here Notes on building the BATC v2 Minitiouner. This pdf includes a Panel layout for the Hammond Box.
Parts list and schematic
Setting up the hardware
Once you are satisfied the voltage levels are correct and there is no smoke, you need to connect your hardware up to a Raspberry Pi4 Ryde receiver or a PC running the MiniTioune software.
Full details including how to set up the MiniTiouner software, drivers and decoders is on the MiniTioune software page.
On the air
Serit LNB DC supply problems
A number of people on the BATC forum have reported their Serit tuners are no longer outputting the LNB voltage from one of the F sockets. The cause is inevitably an open circuit inductor (L101 or L102) after the output has been accidently short circuited.
This wiki page has more details of how to repair a broken tuner and details of an add on PCB with a DC current limited supply.
