Getting Started
Revision as of 17:01, 5 July 2021 by G8XZD (talk | contribs)
One of the aims of the BATC is to help members get on the air. Probably the easiest way to achieve this is by using drone FM transmitter/receiver modules - take a look at this page which shows you how to join in the fun on 5.6GHz for around £20.
This is enough to get good quality pictures over a few miles over line-of-sight paths with simple aerials - though with a better aerial and a good portable location at both ends of the link - it is possible to work hundreds of miles during favourable atmospheric conditions (the proverbial "bit of a lift on there old man").
Alternatively the club has come up with the Portsdown project which is easy enough for most people to successfully build at home and gives you the basics of a very credible DATV transmitter (It can also be upgraded to receive DATV)
Hundreds of these have been built by amateurs around the world and part of its success is down to the club prescribing the key components/design (and you sticking to them...) and following simple build instructions.
Yes I know radio amateurs (me included) like to tinker and experiment but at this stage it really helps our volunteers help you. That way, if there are any problems, it's easy to offer support via the BATC forum. And if you still can't get it going bring it along to one of our Portsdown clinics which are held at most rallies the BATC attends.
The best way forward:
We often get asked how do I start to receive or transmit DATV?
Receiving DATV:
Probably the most repeatable way to do this is to build up a Minitiouner board. It was designed by Jean-Pierre Courjaud, F6DZP, and can be used with his excellent free MiniTioune Windows software.
You can find out more on the Minitioune wiki page: https://wiki.batc.org.uk/MiniTioune
The PCB and other "hard-to-get" components can be bought from the BATC shop https://batc.org.uk/shop/ - the remainder are standard leaded (no surface mount) components, available from all major suppliers. and can easily be put together in an evening.
With this you can receive local DATV activity from 2m to 13cm, including digital TV repeaters, and with a satellite dish and LNB, you can watch the activity on QO-100.
Jean-Pierre's software also comes with a suite of programmes to allow you to test that the board is talking to the software correctly.
You will then need the normal aerials, filters/pre-amps and/or LNB depending on the band you want to receive. Having said that it is relatively sensitive enough on its own to be able to receive nearby activity - and probably your local digital TV repeater.
Once you've tested the board works correctly and you want to upgrade tour receiver have a look at at the BATC Ryde DATV receiver project: https://wiki.batc.org.uk/Ryde_Receiver This is a set top box-style receiver based around the Raspberry Pi 4 and an infrared hand controller.
The Ryde's main advantage is you don't need to have a PC on and it produces good quality pictures via an HDMI cable (you can use composite video if you must...) From the hand controller you just tell it the frequency and symbol rate - and it does the rest.
DATV transmit:
For more details see https://wiki.batc.org.uk/The_Portsdown_Transmitter
DATV transmit and receive in one box:
The Portsdown 4 software includes everything you need - just make sure you have the latest build - and plug your tuner card in to the Pi's USB port. See https://wiki.batc.org.uk/Portsdown_4_Pluto for more details.
