Config File Error Messages
Jump to navigation
Jump to search
If there is an error in the Configuration files stored on the Portsdown SD Card, or one of the configuation files is missing, an error message will appear on the Portsdown Screen.
To correct the error, there are 2 or 3 options:
- A factory reset can be performed to rewrite the configuration files. If the touch screen is still operating, the factory reset can be initiated from Menu 3, System Config, Restore Factory. If not, log in by ssh, type menu and press enter. Then down-arrow to System 2, press enter and then down-arrow to Factory Settings and press enter.
- The file can be manually corrected using a text editor.
- Sometimes the erroneous entry can be corrected from one of the Portsdown Menus.
