GB3CT - Caistor IO93UM
TX: 3404Mhz DVB-S2 1M/s - 2/3 FEC
70cm RX: 437Mhz 333k/s - 1M/s - 2M/s
13cm RX: 2435Mhz Analogue FM & 2335MHz Digital 333Ks / 1Ms / 2Ms / 4Ms Note: This is a shared input and the default is digital switching to analogue when valid sync is detected on 2435Mhz FM. Please ensure digital is not in use on the 13cm input before transmitting analogue on 2435Mhz
2x Skype inputs (GB3CT1 & GB3CT2) are provided which will require you to pre-register once only by Emailing your amateur radio licence document to gb3ct.repeater@gmail.com. This is required as your Skype video will be transmitted on GB3CT's 3404Mhz output. Once registered, your Skype ID will be added to the authorised users list and the Skype interfaces will automatically answer your video call. Once answered, the skype interfaces use video motion detection to switch the repeater logic, so it is important that you provide some motion on your Skype video at least once every 30 seconds. Failure to do so will cause the repeater to close down the input until further video motion is detected. You will continue to keep the Skype input until you hang up your call, so it is important to remember to terminate the call when done.
Caistor Top, Lincolnshire -IO93UM
