Repeater Controller
Revision as of 13:03, 12 January 2022 by G8GTZ (talk | contribs)
The RPi will control a video switcher either by Infra Red or GPIO pins and will generate a carousel of images. On receipt of a valid signal from, for example, a Ryde receiver, it will switch to that input - when the receiver closes, the logic will play a key sequence, dekey the tx and go back to the carousel.
GPIO Connections
