Repeater Controller
Revision as of 14:09, 13 January 2022 by G8GTZ (talk | contribs)
The RPi will control a video switcher either by Infra Red or GPIO pins and will generate a carousel of images. On receipt of a valid signal from, for example, a Ryde receiver, it will switch to that input - when the receiver closes, the logic will play a key sequence, dekey the tx and go back to the carousel.
GPIO Connections
Configuring IR Switching
The application used by the repeater software to control an IR switch is different to that used on the Ryde, but uses some common components. Full information on configuring the IR switching is here: Repeater LIRC Configuration.
