Repeater Controller
The outline requirement specification is here.
The RPi will control a video switcher either by Infra Red or GPIO pins and will generate a carousel of images. On receipt of a valid signal from, for example, a Ryde receiver, it will switch to that input - when the receiver closes, the logic will play a key sequence, dekey the tx and go back to the carousel.
Customisation
While this software is designed to work "out of the box" it will need to be configured for each individual repeater (with callsign at the very least). Most customisation will require the careful editing of the text file /home/pi/atv-rptr/config/repeater_config.txt; following this, the repeater will need to be rebooted to load the new settings (although you can just type "restart" at the ssh command prompt for testing). Some real-time control is possible using the ssh Console Menu (type menu at the ssh command prompt), but the configuration file is too comprehensive for all the functions to be edited from a simple menu.
Switching Logic
GPIO Connections
Configuring IR Switching
The basic design uses one or 2 IR transmitters to control one or 2 HDMI switches. The exact IR codes for the HDMI switch used on your repeater will need to entered in the configuration file. Full details are here: Configuring IR for HDMI Switching
