Repeater LIRC Configuration
Setting Up the Key Codes
Use your Ryde receiver to record the key codes from the IR sender for your HDMI switch.
To do this you will need to go to log in to the Ryde by ssh, and type "menu" and press enter. This should bring up the Console Menu. Go to Select option 7, IR Check.
See this page for more details: https://wiki.batc.org.uk/Ryde_remote_controls#Using_a_custom_remote_control
Recording the Codes
You will need to make a list of the key codes that you want to use, and also check the protocol used. Press a key and you should see a response on the screen like this:
8950.350025: lirc protocol(nec): scancode = 0x17
8950.350035: event type EV_MSC(0x04): scancode = 0x17
8950.350035: event type EV_SYN(0x00).
The information required is the protocol (nec in this case) and the scancode (0x17 in this case). Here are 2 example lists of keycodes:
Portta 4-port HDMI Switch. Protocol nec.
Key scancode
Input 1 0x17
Input 2 0x12
Input 3 0x59
Input 4 0x08
Quad View 0x18
Generic eBay 4-port HDMI Switch. Protocol nec.
Key scancode
Input 1 0x19
Input 2 0x1b
Input 3 0x11
Input 4 0x15
Quad View 0x04
Note that only the following protocols are supported: nec, necx, nec32, sanyo, rc6_0, rc6_6a_20, rc6_6a_24, rc6_6a_32, rc6_mce, rc5, rc5x_20, rc5_sz, jvc, sony12, sony15, sony20, sharp.
Formatting the Codes for the Configuration File
The configuration file includes a number of lines for IR codes. This is how they should be configured for the Portta 4-way HDMI switch described above:
outputswitchcontrol=ir
outputhdmiresetcode=nec:0x17
output2ndhdmicode=nec:0x08
output0code=nec:0x17
output1code=nec:0x12
output2code=nec:0x59
output3code=nec:0x08
If a second identical switch were to be daisy-chained in front of input 4 (to give 7 available inputs including the controller), the codes would be:
output3code=2nec:0x17
output4code=2nec:0x12
output5code=2nec:0x59
output6code=2nec:0x08
So, the format for the codes is protocol:scancode. If the desired input is daisy-chained, the format is 2protocol:scancode, and the "output2ndhdmicode" must refrence the code to select the second controller.
