Initial setup
Revision as of 17:22, 3 January 2017 by G8GTZ (talk | contribs)
Initial set up
Once you have built the Hardware and installed the software, the transmitter must be initially setup using an external PC with 2 pieces of software - the first application is to find the IP address of your RPi when it first boots up, such as Advanced IP Scanner and an SSH Terminal application such as Putty.
Once you have configured the system, you can control the Portsdown transmitter in one of 2 modes: through the console using a second computer or by the use of the Rpi touchscreen - you will set which mode you want to use during the initial setup described here.
  • Using a network lead (not wifi at this stage), connect the RPi to the same network as your PC, and turn it on. After it has booted up, use the IP Scanner to find the IP address of your RPi.
  • Open Putty and enter the IP address of your RPi and open a connection. At the logon prompt enter the default username of pi and the password given to you with the card. The console menu will start automatically and you will see the following screen:
  • Output Frequency. Set the output frequency for your ADF4351 synthesizer here. If you are using QPSKRF “ugly” mode, set 437 MHz only.
  • System Setup. It is important that you set your display type first here, so select Display. If you want to use the Waveshare touchscreen to control the Portsdown, select it with the spacebar and press enter. Note - if you want to continue to use the console mode, make sure that Console is selected.
  • System Setup Autostart. After you have selected the display type, you can select how you want your RPi to start up.
Your Portsdown transmitter is now set up and ready for use but will require a reboot for the configuration to take effect so go into the Shutdown menu and select Reboot. The Portsdown will now restart in whichever mode you set in the System Setup Autostart menu. Please refer to the appropriate section of the Portsdown Transmitter user guide for console or touch screen operation.
