Changing system setup
Revision as of 17:29, 3 January 2017 by G8GTZ (talk | contribs)
If your Portsdown transmitter is normally configured to boot up and be used in Touchscreen mode and you want to change some parameters such as station name simply follow this procedure:
  • Connect the RPi to the same network as your PC, and turn the Portsdown on. After it has booted up, use the IP Scanner to find the IP address of your RPi.
  • Open Putty and enter the IP address of your RPi and open a connection. At the logon prompt enter the default username of pi and the password given to you with the card. The console menu will start automatically and you will see the following screen:
