IARU ATV contest
Update for 2022
The IARU Region 1 ATV Contest will go ahead on the weekend of 11/12 June. Unlike the past 2 years, there will only be a single section that includes both portable and home stations.
Please use the entry spreadsheet here: File:ATV-contest-log-callsign-20220611.xls.
The normal rules can be found at Media:2022_ATV_Contest_Rules.pdf.
Entries should be submitted to your National Coordinator and then passed to me. I will accept entries direct on the e-mail address atv@iaru-r1.org if you are unable to contact your national coordinator.
Please pass this on to any prospective participants – just for 2 days, we need to get people off of QO-100 and onto the other bands!
Dave, G8GKQ, IARU Region 1 ATV Contest Coordinator.
Who can enter?
What Bands are in Use?
The IARU region 1 ATV Contest includes all harmonised amateur bands above 400 MHz.
Note: Only the UK has the 71 and 146MHz bands and so are not included in the IARU ATV contest.
Signal reports
DXSpot.TV https://dxspot.batc.org.uk/ was set up to co-ordinate ATV contacts and have a real time chat room where you can message other ATV operators directly - we suggest you register for an account before the contest.
You can access the DXSpot.TV chat room over low bandwidth (2G?) links using this address: https://dxspot.batc.org.uk/chat/
Time of contest
Submitting an entry
While the important thing is that you get "on the air" at sometime over the weekend, it would be great if you also took the time to submit an entry, even if it is only for a single 5km QSO across town using the 5665MHz drone equipment you just got working! That way we can show to Ofcom and other users that there is real activity on the ATV bands and also so the UK can have highest number of entries in the contest!
Ideally you will submit an entry on the official Excel Spreadsheet which you can download from here Media:ATV-contest-log-callsign-20190608.xls or here (the same file, different name) Media:ATV-contest-log-UK-V4a-2020.xls
Alternatively, simply email in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received to contests@batc.tv.
Contact scoring
  • For contacts on the 71 and 146 MHz bands: 2 points/kilometre (BATC Contest only)
Previous year's results
The number of stations entering the contest across Region 1 is as follows:
2014 = 33
2015 = 42
2016 = 52
2017 = 95
2018 = 100
2019 = 55 (down possibly because of the distraction caused by ATV Activity on QO-100).
2019 contest results
Noel G8GTZ was the top UK station and also band winner on 24GHz along with G4FRE.
Full results can be found here https://www.iaru-r1.org/wp-content/uploads/2019/09/IARU-Region-1-ATV-Contest-2019-Results.pdf
BATC also ran a 71 and 146MHz contest alongside the main event - results can be found here: https://forum.batc.org.uk/viewtopic.php?f=75&t=6206
2018 contest results
UK stations won both the 24GHz and 76 GHz sections and Rob M0DTS was the highest placed UK station.
A full list of the UK results can be found here.
2017 contest results
Certificates
More information
