Changing system setup
Revision as of 17:44, 3 January 2017 by G8GTZ (talk | contribs)
If your Portsdown transmitter is normally configured to boot up and be used in Touchscreen mode and you want to change some parameters such as station name simply follow this procedure.
  • Connect the RPi to the same network as your PC, and turn the Portsdown on. After it has booted up, use the IP Scanner to find the IP address of your RPi.
IMAGE IN here of keyboard monitor mode
To exit Touchscreen mode press the "Ctrl" and "C" keys on the PC keyboard simultaneously - the Touchscreen will go blank, the the console menu will start automatically and you will see the following screen:
You can now make any changes you require and as long as you do not change the autostart configuration, the Portsdown will automatically boot back in to Touchscreen mode when restarted.
