8-Band RF Output Switch
Revision as of 23:15, 10 June 2022 by M0JUR (talk | contribs) (If I manage to upload it, the latest parts list will now cover version 3.0)
For those of you who want to drive Microwave transverters from your Portsdown or need a higher drive level, the team have developed an 8-Band RF output switch that includes an RF amplifier.
It is capable of amplifying the variable level from the Filter Modulator board / Lime SDR up to 10 dBm and switching it to separate external amplifiers for the 70, 144, 437, 1255 bands and up to 4 transverters for the higher bands. One of the 4 transverter output can also be used for 2300 / 2400 MHz - see mods below to maintain output level.
The module should be used with the 8 band decoder which will provide PTT steering for the 8 bands - see this page for more details.
PCBs and the control PIC are available from the BATC Shop.
The latest parts list is here File:8_BAND_RF_SWITCH_V3.0_PARTS.xls.
Version 3 PCB - October 2021
We have seen a number of failures caused by the use of the 8 way switches with the LimeSDR (the PCB was originally designed for use with the Filter-Modulator Board). The problem with the LimeSDR is that it can easily deliver +17 dBm during its calibration pulse, thus feeding +22 dBm into the RF switch, which exceeds its absolute maximum rating at 146 and 437 MHz.
The version PCB provides a solution by increasing the attenuation on the input to the 8-way RF switch, or to use a lower gain RF amplifier. The revised layout is as show:
Version 2.2 PCBs
The circuit for Version 2.1 and 2.2 PCBs is here: Media:8 BAND RF SWITCH V2-1 SCH.pdf. Note that the value of C13 should be increased to 2.2 uF to prevent the 5V regulator from oscillating.
Version 2.1 PCBs
The previous version, V2.1 requires 2 minor corrections during construction.
Lime SDR
When used with the Lime SDR, Dave G8GKQ recommended changes to the input attenutor in his article in CQ-TV 262 to improve performance at 2.4GHz. C16 changes to 1pF and R5 becomes a Zero Ohms link. The modification is shown here on a prototype PCB with the 1pf capacitor on the white square.
All the parts in the attenuator are 0603 sized; the V2.3 arrangement is in the revised parts list.
Here is a V2.3 PCB for LimeSDR Mini use, and the underside showing the wire link. Assembled by David M0YDH
Version 1 PCBs
The initial design was as shown above - the first batch of boards will be supplied in this form. The initial (V1.0) circuit is here: Media:8 BAND RF SWITCH V1-0 SCH.pdf.
