This page is designed to give an overview of the Portsdown transmitter project - for more details and an FAQ see the user guide. For interactive discussion with other constructors see the BATC members forum:
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost, covers most of the common modes and involves some basic construction.
• Symbol rates to include the Reduced Bandwidth (RB-TV) modes and “normal” DATV modes
Block Diagram
System description
A touch screen interface on the RPi enables the system to be used without further need to connect up keyboard and mouse. If the LCD is not available, the system can be controlled by using an external PC connected over a wired or wi-fi network (console mode).
The output from the Rpi is connected to a
The Portsdown RPi software is capable of controlling the ADF4351 Local Oscillator module to give an output for 146 MHz, 437MHz and 23cms.
