This page is designed to give an overview of the Portsdown transmitter project - for more details and an FAQ see the user guide. For interactive discussion with other constructors see the BATC members forum:
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost, covers most of the common modes and involves some basic construction.
• Symbol rates to include the Reduced Bandwidth (RB-TV) modes and “normal” DATV modes
Block Diagram
System description
The output from the Rpi is connected to the Filter Modulator board (the only custom piece of hardware - PCBs will be available from the BATC shop). This board also requires an on frequency local oscillator signal and the Portsdown transmitter software has been designed to control an ADF4351 chip (available from ebay) to give an output on 146, 437 and 23cms.
The Portsdown RPi software is capable of controlling the ADF4351 Local Oscillator module to give outputs on 146 MHz, 437MHz and 23cms.
