Revision as of 16:38, 7 January 2017 by G8GTZ (talk | contribs)
This page is designed to give an overview of the Portsdown transmitter project - for more details and an FAQ see the user guide. For interactive discussion with other constructors see the BATC members forum:
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost, covers most of the common modes and involves some basic construction.
• Symbol rates to include the Reduced Bandwidth (RB-TV) modes and “normal” DATV modes
System description
Touch screen control
Modulator and Filter board
Audio and video inputs
