MiniTioune software
Revision as of 09:42, 25 April 2023 by G8GTZ (talk | contribs)
Unfortunately, due to a family bereavement F6DZP is currently not developing the MiniTioune software – MiniTioune has become the go-to Windows software for DATV reception and the ATV community wishes Jean Pierre well for the future.  However, all is not lost as coincidently Tom ZS6RTG released the first version of his Windows OpenTuner software in March 2023 which uses the same standard MiniTiouner hardware.  See OpenTuner for more details.
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP.
The Software, which will run on a PC with Windows 7, 8 or 10 operating system, is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software. Please note MiniTuioune is not open source and will not run under Linux or MAC o/s.
Once you have a log-in, V0.8 (latest version at Dec 2018) can be downloaded from here: http://www.vivadatv.org/viewtopic.php?f=60&t=521
Version 0.8 and later
You must do a small modification to the hardware to run Version 0.8 or later software before starting the program - see MiniTiouner_hardware_Version_2#MiniTiouner_version_0.8_software
Previous versions
You will need Version v0.6 or newer if you have built a MiniTiouner Version 2 board with a Serit tuner (or a Serit tuner on a version 1 board with adapter card). Full installation procedure is at the bottom of this page.
Connecting the hardware
It is absolutely essential you use a high quality USB cable or the program will frequently freeze and crash with no warning
The recommended cable is a Lindy Cromo Lindy cable USB 2.0 type A/mini-B 1m long.  https://www.lindy.co.uk/cables-adapters-c1/usb-c449/1m-cromo-usb-2-0-type-a-to-mini-b-cable-p6866
Running the test software
Connect up your MiniTiouner to the PC USB port and apply volts - then run the test programs found in the directory where you extracted MiniTiouner to.
All test should pass - if it fails the USRC filter test try running the install_usrc_ax_winXP.exe file in the directory and run the test again.
If you have completed the installation and tested your system by running the test programs, you now need to arrange a test signal which can be one of the following:
  • DVB mode - DVB-S or DVB-S2
Start the program and you should see the please wait message. If you get the USB error message then you hardware is not connected.
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2. For ATV operation make sure the DVB-S box is ticked and not auto.
If you are using a Serit tuner, which covers 144 - 2550 MHz without any upconverters, make sure you have NO offset in the white box under the frequency box.  If there is a a number present simply enter "00000000" to overwrite it.  If you are using a Sharp tuner with an upconverter you will need to enter the L band frequency in the green box or the receive frequency in the green box plus LO offset in the white box.
The 3 "lights" at the bottom left of the screen should now turn green, the meters should indicate signal level and MER, you should see dots in the 4 quadrants of the constellation window and the Viterbi error bar graph should go green.
If this has happened but there is no video displayed in the center window, navigate to the top right of the screen and click the "Auto PID" button which should be green - the video should now appear!
MiniTiouner Indicated Power Levels
The power level indicated on the MiniTioune display is only indicative. More details about this indication here: MiniTiouner Power Level Indication.
  • Place a jumper on J3, which is near the 12v power socket. Check that there is now 12v on the upper NIM F socket.
  • Connect the upper NIM socket to a Sky dish.
  • Start the MiniTioune software.
  • In the frequency setting area in the top left of the screen, put 09750000 into the OFFSET box.
  • Click the PLUS / MINUS indicator next to it so that it shows MINUS.
  • Put 10758000 into the FREQ box.
  • Put 22000 into the SR box.
Note the MiniTiouner hardware does not generate 22KHz and will not switch in the High LO in an LNB.  However, as the tuning range of the MiniTiouner with a Serit tuner goes up to 2450MHz it is possible to receive the higher channels by using the 9750 offset described above.  Simply take 9750 off the channel frequency and enter the result in to the frequency box.
To receive the horizontal channels either supply 18v to the LNB supply via fuse 2 (be very careful not to short to 12v!) or simply turn the LNB on the dish through 90 degrees.
Signals received but no video displayed
MiniTiouner uses 2 seperate USB channels to communicate with the PC / LongMynd receiver.
  • The first channel is used for control of the hardware and to display all the signal parameters on the PC screen.
  • The second channel is used just to send the demodulated transport stream data from the hardware to the PC. This contains the video and audio packets plus the service information containing program name etc.
Very occasionally users have found that the software detects the MiniTiouner and displays all the signal parameters including green indicators but there is no video decode as shown in the above screen shot.
The very first thing to try is to navigate to the top right of the screen and click the "Auto PID" button which should be green and not red - the video should now appear. (Note prior to putting Auto PID on, there would be no program name shown in the white box or provider listed.)
If that does not fix it - read on...
The problem might just possibly be due to a tuner or USB module failure but we have had less than 10 hardware failures from 1,000 units sold, so it is almost certainly due to corruption of the software filters / decoders installed on the PC to display the video.
If the program and provider name is shown on the right hand side of the screen but no video appears, the hardware is 100% OK - in the above screen shot the program name A71AU and provider QARS is shown as this is the QO100 beacon.
The most common cause of this problem is corruption of the LAV filters and is resolved by running the install_usrc_ax_winXP.exe file in the MiniTiouner program directory.
If this does not solve the problem we recommend deleting the complete program directory (don't forget to save your .ini file if you have changed it) and then download version 0.8 http://www.vivadatv.org/viewtopic.php?f=60&t=521
This is an older version but has the support files not present in the version 0.9 zip file http://www.vivadatv.org/viewtopic.php?f=60&t=625
There should be a file "Read_Me_Minitioune v08s.pdf" that has the instructions. There are also test programs, Lav Filter installers etc. Run the CheckMiniTiouneDriverAndFilters_V0_5a.exe and address any problems it reports.
Once this is working, you should be able to run version 0.8. You can then download 0.9 from http://www.vivadatv.org/viewtopic.php?f=60&t=625
If this does not cure the problem - ask for help on the BATC forum here https://forum.batc.org.uk/viewforum.php?f=105.
Other controls
Set of soft controls located at the bottom right of the screen.
A typical display from the Data reader
You can edit the miniTioune.ini file in the download directory to configure various options to be set when you start the program including:
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
  • Expert screen off for start up
Web monitor
The web monitoring panel will now show your call sign and locator - tick the "auto" box and turn the monitor switch on.
Using MiniTioune with VLC
You may find that some stations seem to have jerky video or poor intermittent sound and can be decoded more reliably with the open source VLC player.
This is because MiniTioune uses the standard Windows demultiplexer to decode the audio and video and this is very critical on timing of the incoming signal.
If the incoming signal is not strictly DVB compliant and has PCR or PTS errors (the PCR timing must be less than 500 nano seconds) the Window demultiplexer will not decode it properly and it has been found that VLC is more tolerant to errors.
  • To use VLC player on the same PC, edit the MiniTioune .ini file (found in the same directory as the MiniTioune program) as follows:
; adresse UDP / UDP address
[UDP]
AddrUDP=127.0.0.1
Port=1234
Note in Version V0.9beta8 the following line needs to be removed or commented out
TS_AddrUDP=230.0.0.10
Now launch VLC, go to Media > open network stream and enter udp://@127.0.0.1:1234 in the network URL box and press play.
  • To use VLC and a seperate device (PC, Media player, Raspbery PI etc) put the IP address of the player device in the MiniTiouner .ini file and then put udp://@:1234 in the VLC network address on the remote device.
Expert Mode
To be completed.....
Ken W6HHC has a written a very comprehensive user guide for MiniTiouner-Express system which uses the same software as the BATC hardware - this is available here https://www.datv-express.com/uploads/UserGuide/MiniTouner-Express%20User-Guide-draft15.pdf
Software Installation V7 and before only
For a very comprehensive guide on the software installation, see the user guide written by W6HHC - http://www.w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
