Revision as of 14:56, 19 February 2024 by G8GKQ (talk | contribs)
SSH Menu
Reload
1 Behaviour
5 - Operating hours. Selection of transmit key line to be active continuously or just during a timed period to save power. If timed, select the start and stop times. Note time is set using UTC time, not local time.
8 - Half hour. If enabled, the transmitter will only be keyed in beacon mode during the first 30 minutes of every hour and not during the 2nd half hour to save power.
11 - Apply changes
12 - Return to main menu
2 Callsign
3 Inputs
10 - Apply
11 - Main Menu
4 Control
5 Update
6 Settings
1 - Reset factory defaults
3 - Main menu.
7 Diagnostics
8 Reboot
Does exactly that!
Controlling the Repeater During Testing
Stopping the Controller
The controller can be stopped by entering
stop
at the command line. This tells all the repeater processes to stop and should show a "Controller Software Not Running" caption on the HDMI output.
Restarting the Controller for Testing
You can restart the controller for testing by entering
rptr
You will see a running commentary of what the repeater is doing in the console window. However, if you close the window, the repeater will stop. You can also stop it and get back to the command prompt by pressing ctrl-c.
You can start the repeater so that it runs and keeps a log of what it is doing (even if you close the controller window) by entering this command:
nohup atv-rptr/utils/run_rptr_nohup_with_log.sh &
Then press ctrl-c to get back to the command prompt.
If you see behaviour that you want to investigate, enter
stop
to force the last bit of the log to be written to the file, and then enter
tail -25 log.txt
to see the last 25 lines of the log.
Do not run the repeater for normal use using these test modes. The log file will grow over time and eventually fill the SD Card, causing the repeater to fail.
Getting Back to Normal Use
At the end of a maintenance session, you should always reboot the repeater to check that it is working properly and put it in its normal mode. Do this by typing
sudo reboot now
Close the SSH window, watch the repeater output and if all is well, walk away.
Advanced Commands
If you need to edit the C code, you can recompile it and run the repeater software with the command
urptr
This will also show you any errors if the compilation fails.
If you need to troubleshoot the output display settings, use
tvservice -s
Editing the config file
Hand edit
You can hand-edit the configuration file with the command
nano atv-rptr/config/repeater_config.txt
Use the arrow keys to move about (not the mouse) and save by pressing ctrl-x, y and then enter. Discard changes by simply pressing ctrl-x and then n.
If it has all gone wrong, you can start again with a factory-fresh configuration file using the command
cp atv-rptr/config/repeater_config.txt atv-rptr/config/repeater_config.txt.factory
Note that you will lose all of your previous edits.
FTP
Use a program such as WinSCP or Filezilla and either edit the config file in the RPi directory or copy it to a local drive, edit and then transfer it back.
Actioning the changes
After editing and saving, reload the controller by using item 1 in the SSH menu.
Typical config file
Read at boot time and only modified from console menu or text editor except transmitenabled which is amended by dtmfkeepertxoff or dtmfkeepertxon
callsign=GB3HV
locator=IO91LD
Video output
vidout=hdmi1080
Ident and K CW audio output
This is used to set the output port (but not the hdmi keep-alive)
hdmi, jack or usb
audioout=hdmi
audiokeepalive=yes
audiokeepalivelevel=85
TX key and Power Saving logic - also in SSH menu (see above for description)
transmitenabled=yes
beaconmode=no
transmitwhennotinuse=yes
Control mains switch for rack (and allocate GPIOs?).  Not not compatible with use of input 7
rackmainscontrol=yes
GPIO pins for controlled rack shutdown (front panel button, shutdown signal and mains switch
racksdbuttongpiopin=21 racksdsignalgpiopin=24 rackmainspwrgpiopin=15
Turn off receiver rack and encoder to save power?  Times UTC
rackpowersave=yes rackpoweron1=1500 rackpoweroff1=2300
Set second times to be equal for one power-on period only
rackpoweron2=0000 rackpoweroff2=0000
24houroperation=yes
halfhourpowersave=no
operatingtimestart=1300
operatingtimefinish=2330
Quiet hours behaviour:
repeatduringquiethours=no
identduringquiethours=no
Recommended pin 40
pttgpiopin=40
Front Panel Shutdown Enabled?
Physical GPIO Pin (recommended 26)
fpshutdown=no
fpsdgpiopin=26
DTMF repeater control
Uses white "Portsdown/Langstone" USB dongle input
These are just example commands - see DATV repeater DTMF commands for more details
dtmfcontrol=on
dtmfaudiogain=62
dtmfactiontimeout=600
All dtmf codes are of the format *xx#.  Only xx isdefined below.  Examples:
dtmfreset=00
To display the controller status screen - includes GPIO pin status (see below)
dtmfstatusview=01
Select quad view
dtmfquadview=04
Select input (when finished, use *00# to return to normal operation)
dtmfselectinput0=10
dtmfselectinput1=11
dtmfselectinput2=12
dtmfselectinput3=13
dtmfselectinput4=14
dtmfselectinput5=15
dtmfselectinput6=16
dtmfselectinput7=17
DTMF Keeper codes
In this example keeper codes are 5 digit and must start with 9 (*9xxxx#)
Turns Tx key on / off
dtmfkeepertxoff=97350
dtmfkeepertxon=97351
Reboot controller
dtmfkeeperreboot=97359
DTMF input can also be used to control external equipment via the GPIO pins - a maximum of 10 devices can be connected.
Number of outputs
dtmfoutputs=1
Pin allocations
dtmfgpioout1pin=8
Label for status screen
dtmfgpioout1label=shack_light
DTMF commands to turn on and off
dtmfgpioout1on=31
dtmfgpioout1off=41
GPIO inputs
The controller can monitor GPIO pins and display their status on the status screen, displayed by DTMF *01#  Note: Due to an error in coding, these functions are called "dtmf"gpio inputs.
Number of inputs
dtmfinputs=1
Pin allocationa
dtmfgpioin1pin=8
dtmfgpioin1label=cabinet_door
Caption cards such as "K" and input identification are built by the controller on this back ground - to change this, replace the .jpg with a different file of the same resolution
Ident info
identinterval=900
identmediatype=jpg
identmediaduration=5
identcwaudio=on
identcwspeed=15
identcwpitch=800
identcwlevel=50
K information
kmediatype=jpg
kmediaduration=5
kmediafile=/home/pi/tmp/k.jpg
kcwaudio=on
kcwspeed=20
kcwpitch=800
kcwlevel=50
kcwfile=/home/pi/tmp/k.wav
Carousel information
carouselscenes=5
carousel01mediatype=jpg
carousel01file=/home/pi/atv-rptr/media/HVtest.jpg
carousel01mediaduration=10
carousel02mediatype=jpg
carousel02file=/home/pi/atv-rptr/media/weather.JPG
carousel02mediaduration=10
carousel03mediatype=jpg
carousel03file=/home/pi/atv-rptr/media/75cbw.jpg
carousel03mediaduration=5
carousel04mediatype=jpg
carousel04file=/home/pi/custom_media/tropo.JPG
carousel04mediaduration=10
carousel05mediatype=source
carousel05file=4
carousel05mediaduration=30
The example above has 4 images and one source (so 5 scenes). The 5th scene is the quad view; source 4 is set up below to show the Quad to enable its inclusion in the carousel.
Note that the 4th image above is located in the /home/pi/custom_media folder. It is recommended that site-specific images are saved in that folder, which will not be over-written during software updates.
Analogue Talkback Audio on Carousel
If using an i2c analogue audio switcher, the talkback audio can be enabled during the carousel
# Analogue talkback audio (144.75) can be turned on or off using the MCP23008 i2c switcher
talkbackaudio=on
talkbackaudioi2cbit=7
If using hdmi audio, the talkback can be input on the USB mic dongle (along with the DTMF) and output on the HDMI audio during the carousel. The audio gain is set by the dtmfaudiogain parameter as they both use the same input. Facility introduced in release 202402190.
# Talkback audio on DTMF input can also be output on the controller (k/cw ident) audio channel
# Volume is set by dtmfaudiogain above
controllertalkbackaudio=on
Input configuration
Recommended gpio pins for "input active" are 32, 35, 18, 22, 16, 19 and 21. The availableinputs number must be set to the number of possibly active (external, in addition to the controller) video sources. activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority active inputs (except priority 1 inputs). If showquadformultipleinputs is set to yes, then the quad is sleected when 2 or more if its inputs are active.
Cascaded switches refers to whether 2 4-input switches are daisy chaned t get 7 (controller plus 6 external) inputs.
 availableinputs=6
 activeinputhold=no
 showquadformultipleinputs=yes
 cascadedswitches=no
Output video switch config
The output video switch configuration is defined by this block. The switching method is defined by outputswitchcontrol=. This can be ir, gpio or html. For ir or html, the gpio outputs can also be active if showoutputongpio= is set to yes.
The ir code to reset the hdmi switch (not currently used) is set in outputhdmiresetcode. The ir code to select a second (daisy-chained) hdmi switch is set in output2ndhdmicode. The ir code to select a quad view is set in outputhdmiquadcode.
The outputi2caddress is the base address for an i2c video switch, and the outputi2cquadchannel is the quad select for an i2c video switch. Neither of these codes are currently implemented.
outputswitchcontrol=ir
showoutputongpio=yes
outputhdmiresetcode=nec:0x17
output2ndhdmicode=nec:0x17
outputhdmiquadcode=nec:0x18
outputi2caddress=3
outputi2cquadchannel=9
Bitfocus Companion Server Settings
# Bitfocus Companion (html) server address & port (no trailing slash)
networkctrlurl=http://192.0.1.176:8888
# Other net commands have leading slash
outputquadnetcommand=/press/bank/1/11
The configuration for the controller output 6 elements (currently).
The input0name is the text name displayed on the Configuration screen.
The IR code required to select the controller video and send it to the repeater output is stated in output0code. The format is protocol:hex code. A 2 is added to the beginning of the string if the the input is on the second, daisy-chained, hdmi switch (ie 2nec:0x17). If GPIO switching of outputs is used, the output0hdmiswitchpin indicates which pin should be used. If an i2c-controlled video switcher is used, output0i2cchannel indicates which channel should be selected to display that input. Similarly, if network commands are being used to control an ATEM switch through BitFocus companion, the tail end of the network command is defined by output0netcommand.
For audio i2c switching, the correct bit is set by output0audioi2cbit.
input0name=Controller
output0code=nec:0x17
#output0code=2nec:0x17 (daisy chain)
output0hdmiswitchpin=36
output0i2cchannel=1
output0netcommand=/press/bank/1/8
output0audioi2cbit=0
Configuration of External Inputs
The configuration for each input has 11 elements (currently).
The inputxname is the text name displayed on the "announce" caption and on the Configuration screen. The priority level can be set from 1 to 9. A priority level of 9 means that the input is not displayed unless it is viewed as part of the quad or is directly selected by a DTMF command.
The inputxactivegpiopin is the physical pin number that the attached receiver sets high to indicate that a signal is present. The IR code required to select the input and send it to the repeater output is stated in outputxcode. The format is protocol:hex code. A 2 is added to the beginning of the string if the the input is on the second, daisy-chained, hdmi switch (ie 2nec:0x12). If GPIO switching of outputs is used, the outputxhdmiswitchpin indicates which pin should be used. If an i2c-controlled video switcher is used, outputxi2cchannel indicates which channel should be selected to display that input. Similarly, if network commands are being used to control an ATEM switch through BitFocus companion, the tail end of the network command is defined by outputxnetcommand.
For audio i2c switching, the correct bit is set by outputxaudioi2cbit.
The default announce media settings work with the captions that are generated during repeater start-up. The can be cahnge for custom media if required.
Configure input 1
input1name=Stream Input
input1prioritylevel=1
input1activegpiopin=32
output1code=nec:0x12
output1hdmiswitchpin=37
output1i2cchannel=2
output1netcommand=/press/bank/1/1
output1audioi2cbit=1
input1announcemediatype=jpg
input1announcemediaduration=3
Configure input 2
input2name=QO-100 RX
input2prioritylevel=2
input2activegpiopin=35
output2code=nec:0x59
output2hdmiswitchpin=38
output2i2cchannel=3
output2netcommand=/press/bank/1/2
output2audioi2cbit=2
input2announcemediatype=jpg
input2announcemediaduration=3
Configure input 3
input3name=3.4 GHz Ryde
input3prioritylevel=3
input3activegpiopin=18
output3code=nec:0x08
output3hdmiswitchpin=33
output3i2cchannel=4
output3netcommand=/press/bank/1/3
output3audioi2cbit=3
input3announcemediatype=jpg
input3announcemediaduration=3
Configure input 4
Input 4 is set to display the quad view. This enables it to be included in the carousel (as source 4).
input4name=Quad View
input4prioritylevel=7
input4activegpiopin=22
output4code=nec:0x18
#output4code=2nec:0x12 (daisy chain, not quad)
output4hdmiswitchpin=31
output4i2cchannel=5
output4netcommand=/press/bank/1/4
output4audioi2cbit=4
input4announcemediatype=jpg
input4announcemediaduration=3
Configure input 5
input5name=Mast Camera
input5prioritylevel=7
input5activegpiopin=16
output5code=2nec:0x59
output5hdmiswitchpin=29
output5i2cchannel=6
output5netcommand=/press/bank/1/5
output5audioi2cbit=5
input5announcemediatype=jpg
Configure input 6
input6name=Unused 6
input6prioritylevel=9
input6activegpiopin=19
output6code=2nec:0x08
#output6code=2nec:0x08 (daisy chain)
output6hdmiswitchpin=23
output6i2cchannel=7
output6netcommand=/press/bank/1/6
output6audioi2cbit=6
input6announcemediatype=jpg
input6announcemediaduration=3
Configure input 7
input7name=Unused 7
input7prioritylevel=9
input7activegpiopin=21
output7code=2nec:0x08
#output7code=2nec:0x12 (daisy chain)
output7hdmiswitchpin=24
output7i2cchannel=8
output7netcommand=/press/bank/1/7
output7audioi2cbit=7
input7announcemediatype=jpg
input7announcemediaduration=3
