HAMTV from the ISS
The unit failed in 2019, and was returned to earth for repair. It is expected to be returned to the ISS on the SpaceX SpX-30 flight currently scheduled for March 12th 2024. It is hoped that it will be recommissioned by a visiting astronaut within a few weeks of its arrival.
HAMTV specifications
  • 2369 MHz
  • 2422 MHz
  • 2437 MHz
DVB-S modulation
  • FEC : ½
RF output
HAMTV antenna
Video format
  • MPEG-2, approx. 2000kbps
  • NTSC
What is HAMTV used for?
Once re-commissioned, it will be tested before school contacts are undertaken and will be added to the AMSAT status page https://www.amsat.org/status/
How to receive HAMTV?
A 1 meter or larger dish is optimum but smaller antennas such as flat plate or patch antennas will work and have the advantage of a wider beamwidth making it easier to track the ISS. They are unlikely to work at low elevations.
Suitable feeds
Pre-amp and filter
ADD IMAGE(S) OF PREAMPS HERE
A low noise pre-amp (LNA) with bandpass filter tuned to 2395MHz should be connected directly to the antenna feed point to minimise co-ax losses. The LNA should have noise figure (NF) less than 1db and a gain of approximately 15 dB.
Receive co-ax cable
Receive Line amplifier
As satellite TV receivers need a high level of signal this should be followed by a line amplifier with greater than 30 dB. You can check if you have enough gain in your receive system by checking the RF signal level on the Ryde, OpenTuner, MiniTiouner or Portsdown DATV receivers - the noise floor should sit between -30 to -70dBm when not receiving any signals when not receiving a signal.
Do I need a downconverter?
Note: place image of Minitiouner here
Digital receivers for HAMTV
Receivers designed for DATV
However, during the last few years many developments have taken and so we now have a choice of software to use with the USB tuner hardware:
  • Ryde - Raspberry Pi 4 based set-top box software designed specifically for receiving narrow band DATV signals.
  • Opentuner - PC based software developed by Tom ZR6TG
  • Portsdown - The BATC designed DATV transceiver system based on a Rpi 4 has a receiver which has been tested and decodes the HAMTV signal
PC software receivers
Receiving the Signal
Tracking the ISS
Testing your system
Measuring sun noise
Portsdown DATV test system
The Portsdown DATV transceiver incorporates a test function that has a continuous noise measurement facility designed to measure sun noise. It is very easy to use. Simply connect the signal from your LNA to the rx port on a Pluto or Lime SDR and run the software - see https://wiki.batc.org.uk/Portsdown_Noise_Meter
SDR continuum mode
Decoding a local signal
Receiving HamTV
https://forum.batc.org.uk/posting.php?f=2&mode=post&sid=9c1b12a07706567454ebeca685548796 (NOT SURE THIS LINK IS CORRECT!)
Ryde Receiver
MiniTioune
