HAMTV from the ISS
Revision as of 09:55, 23 March 2024 by G8GTZ (talk | contribs)
The unit failed in 2019, and was returned to earth for repair. It returned to the ISS on the SpaceX SpX-30 flight on March 21st 2024 and it is hoped that it will be recommissioned by a visiting astronaut within a few weeks of its arrival.
HAMTV specifications
  • 2369 MHz
  • 2422 MHz
  • 2437 MHz
DVB-S modulation
  • FEC : ½
RF output
Estimated power at the antenna is ~ 2 watts.
HAMTV antenna
Video format
  • MPEG-2 Video, approx. 1 Mbits/s
  • MP2 Audio, approx 360kb/s
  • NTSC
What is HAMTV used for?
How to receive HAMTV?
* The LNA / Downconverter should placed as close as possible to the dish feed and high quality microwave cable must be used.
* The upper blue-boxes option is the preferred solution for new builders.
* In the blue-boxes option the line amplifier and filters are at 2.4Ghz and GOOD (not cheap) quality satellite co-ax must be used to avoid the RF level being too low at the receiver.
* The satellite line amplifiers are required to ensure there is enough signal at the receiver input - these may be placed at masthead or in the shack
* The filters are essential, not nice to have!
* The Minitiouner V2 / Pico tuner USB receiver can be connected to EITHER a PC running OpenTuner or Minitiouner software or a Pi4 based Ryde set top box receiver.
Ground station antennas
Rotator (mechanical tracking)
  • 1m dish: 8 degrees beamwidth (+/-4 degrees)
  • 1.8m dish: 4.5 degrees beamwidth (+/-2.2 degrees)
Dish feeds
LNA and Pre-amp
Commercial LNA Options
Band pass Filter
Note that 2395MHz is only 5MHz below the 2.4GHz WiFi Channel 1, so good filtering will be needed to prevent strong, local WiFi signals from getting into the wide band satellite tuner and causing interference or de-sense.
Receive co-ax cable
Receive Line amplifier
Your masthead LNA/LNB MUST have enough gain to overcome your co-ax cable loss.  The satellite line amplifier can be placed at masthead if needed to help overcome the feeder loss or in the shack.  To hear more about the importance of noise figure and gain distribution in a DATV receive system watch https://youtu.be/lfSi7vTQK44?si=wn_wLBjxco3_RnAf
Do I need a downconverter?
Note: The MiniTiouner Mk1 PCB with a Sharp or Eardertek tuner does NOT cover 2395MHz and will require a downconverter.  The Seit NIM also has better RF performance than the Sharp or Eardertek units.
Digital receivers for HAMTV
Receivers designed for DATV
USB Receiver hardware
Mark 2 MiniTiouner PCB
PicoTuner PCB
It replaces the FTDI USB interface on the original PCB with a Rpi Pico module. The Pico is not only significantly cheaper (£5 vs £32) but enables 2 stations to be received at once when used on the QO100 satellite.
The PicoTuner will be released in April 2024 and it will become the recommended solution for new builders.
As mentioned above, the original BATC MiniTiouner Mk1 PCB (available from 2015 to 2017) with a Sharp or Eardertek tuner does NOT cover 2395MHz and will require a downconverter. As well as covering the HAMTV frequency without a down converter, the Serit 4334 has much better RF performance than the original Sharp and Eardertek units and has been integrated into the OpenTuner, Ryde and Portsdown DATV receive systems.
Note Open Tuner, Ryde and Portsdown receivers DO NOT support the Mk1 MiniTiouner hardware.
Ryde
Opentuner
Portsdown
MiniTiouner
PC software receivers
Do note that any software-based receiver is likely to be several dB less sensitive than a hardware receiver, and will require a significantly more powerful computer.
Receiving the Signal
Testing your system
Measuring sun noise
The most useful is to measure the sun noise received on your system. This will not only measure your system performance but if you leave it running for a few hours with your rotator control system set to track the sun, it will confirm the accuracy of your tracking system.
Portsdown DATV test system
The Portsdown DATV transceiver incorporates a test function that has a continuous noise measurement facility designed to measure sun noise. It is very easy to use. Simply connect the signal from your LNA to the rx port on a Lime SDR and run the software.
SDR continuum mode
Decoding a local signal
Once you have checked your system sun noise and tracking accuracy it is worth testing your system can receive a locally generated 2Ms DVB-S signal on 2395 MHz.
You can use the Portsdown Pi4 based system with a Lime SDR to generate this signal.
If you have an SDR capable of transmitting IQ files, there are a couple of small on-air HamTV RF recordings from 2016 that you can use for local playback: live.ariss.org/media/HAMTV Recordings/IQ Files/
  • 5Ms/s Complex Samples
  • WAV (SDRsharp) format
  • Please note that these were recorded on a 0.6m hand-steered dish, so the signal in the recordings will fade in and out of being decodable even with the best receiver!
Actually receiving HamTV
BATC forum
Youtube videos
Comments on this wiki page
