HAMTV from the ISS
HAMTV is the name of the Digital Amateur Television (DATV) transmitter on board the Columbus module of the International Space Station (ISS). It is a DVB-S digital audio and video transmitter, normally on 2395MHz (13cm band).
The HamTV unit was first installed on the ISS in 2013, commissioned in April 2014 and was used for a number of ARISS school contacts in 2016 - 2018. The unit failed in 2019, and was brought back to earth for repair. It was returned to the ISS on the SpaceX SpX-30 flight on March 21st 2024. It was finally installed and first powered on again on 29th July 2025.
Purpose
The primary use of HAMTV is for ARISS schools contacts, when the astronaut will use a camera to show live video of himself and the inside of the ISS to the school during the VHF radio contact.
Outside of school contacts the transmitter is often left switched on to enable experimentation and self-education in the building of ground stations.
Transmission Details
Whilst the transmitter has a number of possible configurations, it is anticipated that most transmissions will be:
  • 2395 MHz, RHCP, 2W power at the patch antenna pointing down from the ISS.
  • Modulation: 2.0 Msymbols/second, DVB-S (QPSK), FEC 1/2
  • Content: MPEG-2 video with MP2 audio.
More details can be found at: HAMTV from the ISS - HAMTV Transmitter Information
How can I watch HAMTV? (without a ground station)
A network of ARISS ground stations contribute to a central feed using the BATC Merger to enable high-quality reception for School Contacts. You can watch the video output whenever ground stations are receiving the signal.
ARISS / BATC HAMTV Ground Station Network: https://live.ariss.org/hamtv/
How can I build my own ground station to receive HAMTV?
Building a ground station to receive HAMTV from the ISS is challenging.
The link budget is a lot less forgiving of non-optimal stations than VHF/UHF, the high 'microwave' frequency brings lots of pitfalls, the equipment can be expensive and/or hard to source, and the limited visibility and fast movement of the space station across the sky can make it time-consuming and frustrating to troubleshoot any problems that occur.
The result however is being able to receive live video from an Astronaut (during school contacts), with your own S-band ground station! You could also talk to ARISS Ops about joining the ground station network and using your antenna to contribute directly to School Contacts.
Components of a typical ground station
  • Antenna - Typically a dish of 0.6-1.2 meters in diameter, with a helix or patch feed.
  • Pointing Mechanism - to follow the ISS across the sky. Can be motorised, or manual for smaller antennas.
  • LNA - Required, and mounted as close as possible to the antenna feed to minimise coax loss at microwave frequencies.
  • Filter - May be required to prevent overload if you have strong WiFi (2400MHz+) or 5G (2380MHz-) nearby.
  • Downconverter - Optional, allows use of non-microwave capable receivers, also reduces loss in long coax runs.
  • Receiver - Needs to be capable of receiving 2.4MHz-wide DVB-S. A good receiver can be more tolerant of issues elsewhere in the ground station.
For more information read: HAMTV from the ISS - How to build a ground station
Social media
ARISS international on Twitter/X: https://twitter.com/ARISS_Intl
ARISS International on Bluesky: https://bsky.app/profile/arissintl.bsky.social
Join and ask questions in the ARISS Discord: https://discord.gg/dQUEE48C
BATC forum
A lot of information is available on the BATC forum: https://forum.batc.org.uk/viewtopic.php?t=4389
Youtube videos
Comments on this wiki page
