Filter Modulator build
Revision as of 10:34, 19 January 2017 by G8GTZ (talk | contribs)
There are 2 ways to get a Portsdown filter modulator board which is the only custom hardware required for the project. Once the design is finalised, built and tested Portsdown modulator boards will be available from the BATC shop This is the easiest way to get one but there will be a delay whilst they are manufactured and tested - current estimate for delivery due to Chinese New Year is mid February 2017 .
To use the facility, sign in to digikey (you will need to register first) and go to my basket and follow these instructions. Once uploaded the Portsdown BoM will look like this:
  • Change the First part Record begins on Row to "2"
  • Use the column drop down boxes to match the first 3 column titles of the .xls file. Note the final 2 columns are for our reference only - on some tape and reel components you ordering more parts than required as this is the most economical price break - you can change these in the .xls if you require.
Note we have limited stocks of the blank PCB at this time and are unlikely to get any more until after Chinese New Year ends on Feb 4th 2017.  We suggest you may not want to order any components until you have confirmation of a PCB being available for you.
Board information
