Filter Modulator build
Revision as of 12:39, 19 January 2017 by G8GTZ (talk | contribs)
There are 2 ways to get a Portsdown filter modulator board which is the only custom hardware required for the project.
Ready built and tested Portsdown modulator boards will be available from the BATC shop This is the easiest way to get one, but there will be a delay whilst they are manufactured and tested - current estimate for delivery due to Chinese New Year is mid February 2017 .
Note we have limited stocks of the blank PCB at this time and may not get any more until after Chinese New Year ends on Feb 4th 2017.  We suggest you may not want to order any components until you have confirmation of a PCB being available for you.
Below is a bare bones parts list, or Bill of Materials, as an .xls file which you can upload to Digikey. If you wish to make any changes such as select the larger heatsink option or delete components you already have, simply amend the item in the "Quantity" column before uploading to Digikey.
Board information
