Filter Modulator build
Revision as of 09:12, 4 February 2017 by G8GTZ (talk | contribs)
There are 2 ways to get a Portsdown filter modulator board which is the only custom hardware required for the project.
Ready built and tested Portsdown modulator boards will be available from the BATC shop This is the easiest way to get one, but there will be a delay whilst they are manufactured and tested - current estimate for delivery due to Chinese New Year is mid February 2017 .
Note: This is not a beginners construction project as the PCB contains 129 surface mount parts including ICs in dense packages.  If you are not used to SMD assembly, we suggest you buy the assembled PCB from the BATC shop.
Parts List
Board information
