Filter Modulator build
Revision as of 17:03, 18 February 2017 by G8GTZ (talk | contribs)
There are 2 ways to get a Portsdown filter modulator board which is the only custom hardware required for the project.
Ready built and tested Portsdown modulator boards will be available from the BATC shop This is the easiest way to get one - current estimate for delivery is late February 2017 .
Parts List
Board information
Soldering the small ICs
Testing the board Once you've completed building your own board you will have to test it - we're currently working out the process but the outline will be something along these lines:
  • Check 5v rail current before fitting semiconductors:
Install Q01 (Reverse voltage protection) and U11 (5V reg). The regulator tab is at 0V so no insulating kit is needed - you will need a suitable M3 nut and screw. In order to leave room to work when fitting subsequent parts you may wish to leave the heatsink unsoldered at this stage so it can be removed easily for access.
Apply 7-8V to J03 observing correct polarity - the pin nearest the corner of the board is +V. Probe the regulator output with a meter - you should measure 5V relative to ground.
The current measured in series with the power lead to J03 and no other semiconductors fitted should be about 8.5mA.
  • Check 5v current rail after fitting semiconductors.
Testing the system
  • Connect all the modules together
  • Go through initial software set up procedure and set to 1255 MHz / 2Ms (chosen because all sat rxs can receive that) using touchscreen or console menu.
  • Check AD4351 is working – listen on selected frequency with a scanner / rig if you don't have a counter.
  • Adjust balance pots – Select test signal from the console menu. Place a voltmeter on +Q and -Q and adjust pots for 0 Volts - you will have to do this several times to get a true balance.
  • Check for signal received picture on the satellite rxr – you may need to rescan for new signals.
  • If you have a minituer system, check for MER readings and make final balance adjustments.
We are currently working out how to check for correct RF level output but there are some very interesting devices appearing on ebay - search for "RF power meter".
