Filter Modulator build
Revision as of 16:11, 4 March 2017 by G8GTZ (talk | contribs)
Parts List
Board information - version 1
Modifications to Improve the Transmitted Spectrum and new Board Versions
The Version 1 boards described above are OK to use on-air as any spurious emissions are about 50 dB below the main transmission, and the modulation "shoulders" will generally be in-band. However there are a few modifications that can be done to improve their output and reduce the level of the "shoulders" at SR1000 and above. The modifications also equalise the levels between low SRs (RB-TV) and higher SRs (1000 and above). These modifications bring the board to "Version 1A" standard. The modifications are described here Filter Modulator Version 1A Modifications.
PCBs supplied before 28 February 2017 are Version 1. Assembled PCBs due to be supplied in Mar 2017 will be at Version 1A, and blank PCBs due to be delivered in March 2017 will be at Version 2 (more details to follow).
Soldering the small ICs
Testing the board Once you've completed building your own board you will have to test it - we're currently working out the process but the outline will be something along these lines:
  • Check 5v rail current before fitting semiconductors:
Install Q01 (Reverse voltage protection) and U11 (5V reg). The regulator tab is at 0V so no insulating kit is needed - you will need a suitable M3 nut and screw. In order to leave room to work when fitting subsequent parts you may wish to leave the heatsink unsoldered at this stage so it can be removed easily for access.
Apply 7-8V to J03 observing correct polarity - the pin nearest the corner of the board is +V. Probe the regulator output with a meter - you should measure 5V relative to ground.
The current measured in series with the power lead to J03 and no other semiconductors fitted should be about 8.5mA.
  • Check 5v current rail after fitting semiconductors.
Testing the system
  • Connect all the modules together
  • Go through initial software set up procedure and set to 1255 MHz / 2Ms (chosen because all sat rxs can receive that) using touchscreen or console menu.
  • Check AD4351 is working – listen on selected frequency with a scanner / rig if you don't have a counter.
  • Adjust balance pots – Select test signal from the console menu. Place a voltmeter on +Q and -Q and adjust pots for 0 Volts - you will have to do this several times to get a true balance.
  • Check for signal received picture on the satellite rxr – you may need to rescan for new signals.
