Assembling Portsdown
This page describes how to build the complete transmitter assembly but you can run the Portsdown as an experiment in "Ugly Mode", currently labelled in the Menu as QPSKRF. That does not require you to wire anything together.
Mechanical Design
First of all, decide on your mechanical design. You are going to need to have the RPi firmly mounted, with the Micro-SD card slot accessible (to change the card if required) and the power, network and USB connectors available. Then you will need to stack a GPIO extender on top of the RPi.
The most difficult part will be to mount the Touchscreen display. It can either be stacked on top of the RPi, or you can connect it by a short multiway lead and mount it on the front panel of your housing - an example is here: http://www.ebay.co.uk/itm/141354697688
f you have a 3D printer you could try make up one of these housing http://www.thingiverse.com/thing:1920486
An example layout is here
Interconnecting the modules
The following diagram shows the interconnects between the various modules - all wire can be non screened (except the Local oscillator feed to the Filter modulator board) but should be kept as short as possible.
Note - the RF output switch design and PCB is not yet available
Higher resolution pdf is available here File:Portsdwon interconnect v2.pdf
Or a picture might help...
BATC GPIO breakout card
The GPIO breakout card is where all the signals and power for Portsdown interconnect and we recommend that you buy the blank PCB from the BATC and make up the breakcard using either connectors or hard wiring to the other boards.
For more details see https://wiki.batc.tv/Portsdown_hardware#GPIO_Extender_Card
Willow components breakout card (If you have bought the BATC GPIO breakout card you DO NOT NEED to read this section)
RF Wiring
Power Wiring
You should power the RPi through the Micro-USB power connector to take advantage of the input protection provided. Use a very short USB cable to your power supply as most of these cables are of very poor quality and cause significant voltage drop.
A lot of strange problems, such as the Portsdown running very slowly, can be caused by poor PSU volts - the Rpi3 is actually specced for 5.1 volts, make sure your PSU delivers enough volts and current. See this post on the BATC forum for a real user experience!
The ADF4351 will operate from the same 5V supply as the RPi. It has an on-board regulator to 3.3V, and digital noise on the power supply has not been observed to cause any problems.
The filter/modulator board needs a clean 5V at 250 mA and the on-board linear regulator supplies this, but can get warm at higher input voltages. It needs at least 7V to operate properly.
An eBay buck regulator capable of supplying at least 1A continuous at 5V is recommended to power the RPi and ADF4351.
Network and USB Wiring
Camera Wiring
Kits are available to connect a female HDMI connector to the RPi camera connector, and another female to the camera, allowing the use of domestic 1, 2 and 3m HDMI leads. The Pi camera HDMI Lead Extension Kit is available from here https://www.tindie.com/products/freto/pi-camera-hdmi-cable-extension/
