The new streamer
Jump to navigation
Jump to search
The new BATC streamer is integrated in to the main BATC website - all members are allocated a streaming channel which is configurable from the account dashboard.
- Configuring your channel Logged in members can configure their channel on the member's account dashboard.
- Channel types Details on members, repeaters and special event channels and how to get one.
Making the Streamer Work in the Chrome Browser
If you get a image of white noise when you try to browse a stream, you need to tell the Chrome browser that the new BATC site is safe for the use of Flash. To do this:
- Right click on the green “Secure” in the address bar.
- Select Site Settings
- Go down to Flash, and select allow.
Your browser will remember this setting and you should not have to do it again for the BATC Site.
Streaming from the Portsdown to the new Streamer
- Log on into Console mode and from the Menu select "3 Output"
- In the Output Parameters Menu select "3 Output Mode"
- In the Output Type menu use the down arrow to highlight "Streamer" and press the space bar and then enter.
- The correct stream URL of rtmp://rtmp.batc.org.uk/live should already be entered.
- Press enter to bring up the stream key page
- Enter your stream name (callsign) in lower case, followed by a hyphen and then the 6 character stream key. For example g8gkq-xYzaBC
- Press enter to get back to the main menu.
