IARU ATV contest
Who can enter?
What Bands are in Use?
The IARU region 1 Contest includes all harmonised amateur bands above 400 MHz.
Note: Only the UK have the 146MHz band and it is not included in the contest.
Signal reports
Time of contest
Submitting an entry
Ideally you will submit an entry on the official Excel Spreadsheet which you can download from here here https://www.iaru-r1.org/images/VHF/atv/ATV_contest_log_-_ATV_yourcall_YYYYMMDD.xls
Alternatively, simply email in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received to contests@batc.tv.
Contact scoring
- For contacts on the 146 MHz band: 2 points/kilometre (BATC Contest only)
- For contacts on the 435 MHz band: 2 points/kilometre
- For contacts on the 1.3 GHz band: 4 points/kilometre
- For contacts on higher bands: 10 points/kilometre
2017 contest results
The number of stations entering the contest is increasing each year:
2014 = 33
2015 = 42
2016 = 52
2017 = 95
Are There Any Prizes?
For the 2018 Contest the BATC will be making the following awards to UK-based stations:
- A £50 Amazon Voucher to the winner of the BATC 146 MHz Contest
- A £50 Amazon Voucher to each station in the Best DX 2-way 5.6 GHz contact
- A £50 Amazon Voucher to the transmitting station using a Portsdown system received at the the furthest distance (any band).
Awards will be presented during the BGM at CAT 18 (on the Sunday).
More information
