Es'hail-2 LNBs and Antennaes
Revision as of 17:05, 30 November 2018 by G8GTZ (talk | contribs)
Octagon LNB
References:
https://f5xg.jimdo.com/antennes/syst%C3%A8me-duo-bande-2-4ghz-10ghz/
http://www.hb9afo.ch/articles/pll-lnb/10ghz_pll-lnb.htm
https://forum.amsat-dl.org/index.php?thread/7-modification-of-octagon-oslo-pll-lnb-for-external-frequency-reference/
We use these LNBs on the FRARS EME system. Attempts to modify the LNB to interface to WG16 or different circular feeds usually lose about 0.3-0.4dB. We are currently trying to work out why... Matching screws do not improve it, so I don't think it is the Lambda-g......
