Using LimeSDR with Portsdown
With the Portsdown Filter Modulator board being discontinued (Jan 2019 - no further FM boards will be available after the current shop stock is sold) it is envisaged the LimeSDR Mini will become the standard modulator for use with the Portsdown system and will be available for purchase in the BATC members shop. More details on the LimeSDR Mini can be found here LimeSDR Mini Information.
Setting up the system
Hardware Installation
Installing the Lime Software
The LimeSuite software version 18.10.0 (Build 2018-12-28, Interface version v2018.10.0, Binary Interface 18.10-1) is loaded as part of the normal Portsdown build and update process. This may not be the latest version, but is compatible with other components of the Portsdown software and DATV Express V1.25lp12.
Lime Configuration Menu
The "Update Lime FW" button updates the Lime SDR firmware and gateware to the appropriate version for the installed LimeSuite. For Portsdown software versions 201811300 and later, the correct versions are shown below. You should see the same screen after selecting "Lime FW Info".
BATC Shop LimeSDR Minis
The LimeSDR Minis purchased from the BATC shop are hardware version 1.2. Those purchased before 14 January 2019 will have firmware 1.26 loaded. Those purchased after 14 January 2019 will have firmware 1.27 loaded. If you have the earlier firmware loaded, the info screen will show:
If the info screen shows version 1.26 (as above), you should upgrade the firmware to the version 1.27 for the best results with the Portsdown (and DATV Express 1.25lp12). Then the Lime FW Info will report:
If you do not use firmware 1.27, the transmitted spectrum will not be as clean. If you are unable to upgrade due to apparent problems with the Portsdown/LimeSDR combination, please report the details on the BATC forum.
Note that if you use a Windows PC or a different Linux build to upgrade the firmware to 1.28 (or an even later version), you can roll it back to Version 1.27 on the Portsdown by typing
LimeUtil --force --update
at the Linux command line. This functionality will be included on the touchscreen menu in a future Portsdown software version.
First power tests with Lime Mini SDR Portsdown at M0YDH
Transmitting
Limitations
System Diagram
Acknowledgements
