Es'hail-2 LNBs and Antennaes
The LNB is the electronics placed at the dish feed which downconverts the satellite frequencies (10,700 - 12,750MHz) to L abnd (950 - 2150MHz) which is then sent down the co-ax to the satellite reciever.
A number of LNBs are suitable for receiving amateur band transmissions and this page lists them.
Octagon LNB
The octagon range of PLL LNBs were the first mass market LNBs to use a PLL rather than free running DRO for the Local oscillator. This made them suitable for receiving narrow band (SSB and CW) signals although they do suffer some temperature drift. The Farnham Web SDR used an unmodified Octagon LNB as the 10GHz receiver for a couple of years.
This drift has caused a lot of people to investigate locking or replacing the internal crystal reference (27 or 25MHz) with an external TCXO or GPS locked source. Details of how to lock a quad LNB are described lower down on this page and the following is a list of links to pages describing modifications and testing the Octagon units:
G4JNT's Modifications and Measurements on a 27MHz PLL Octagon unit
G4JNT's Modification for an External LO (for 27 MHz Octagon LNB)
F5XG's Dual Band Feed for Es'hail-2
HB9AFO's Modifications for an external LO on an Avenger LNB (in French)
CQ-TV 261 page 36 had an article by Dave G4FRE on locking the 27MHz Octagon.
All LNBs are designed for use on the satellite band 10,700MHz to 12,750MHz and using them to receive either satellite or terrestrial amateur transmissions with a maximum frequency of 10,500MHz (in the UK) is outside their publish specification.
We use these LNBs on the FRARS EME system and attempts to modify the LNB to interface to WG16 or different circular feeds usually lose about 0.3-0.4dB. We are currently trying to work out why... Matching screws do not improve it, so I don't think it is the Lambda-g......
The LNB should then be tested with a 25 MHz reference. Note that it will not now operate without a reference signal. If all is well, the cover can be replaced. Before putting the LNB on the dish, I sealed around the cover using a neutral cure silicone sealer. Screwfix 83710 is cheap and does the job.
Suitable 25 MHz Reference
The low pass filter had 5 elements, 288 pf to ground on the input, a series inductor of about 10 turns on a 4 mm core, 407 pf to ground in the centre, then another identical series inductor and 288 pf on the output.
Phase Noise
